6th gear speed/rpms?
  #41
Old 09-24-2011, 07:02 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Originally Posted by Jon0807
This being my first HD, I'm having trouble shifting by "ear" since I don't have a tach yet. I'm not used to the low loping sound of the HD motor. My last ride was an 1100 Yamaha VStar and it sure let me know when I needed to shift. My troubles are mostly with 5th and 6th gear. I've been putting off shifting into 6th till I hit about 70 mph. If I shift at 65 it sounds like I'm lugging the motor. I can stay in 5th till 75 but I'm worried I'm over revving. It also doesn't help that I've found that I've gone 60 mph in 4th gear a few times when I wasn't paying attention to what gear I was in.
My question is, what speed should I shift into 6th gear while cruising or slightly accelerating? Also what are my rpm's at that point?
Hey Jon, yeah I came from an 1100 Vstar also big diff huhh? The manual says you can shift to 6th after 55 so that gives you lots of discretion. Just like the 1100 you've got a rev limiter so don't worry about over-reving the motor just have fun. That 6 speed gives you lots of discretionary shift options.....relax and enjoy.
  #42
Old 09-24-2011, 07:32 PM
T_om's Avatar
T_om
T_om is offline
Wow I wake up to a great amount of info.
... a lot of which is wrong.
How about just Reading The F'ing Manual? You know, RTFM? The saying that has been around forever?
For one example, my 2008 Road King manual says the following:
1st. to 2nd. 15mph
2nd. to 3rd. 25mph
3rd. to 4th. 35mph
4th. to 5th. 45mph
5th. to 6th. 55mph
Those shift points on flat ground work just fine thank you. Amazing how the Harley engineers stumbled onto that, eh?
The alternative is to listen to all the internet experts.
Tom
  #43
Old 09-24-2011, 07:51 PM
DanDil's Avatar
DanDil
DanDil is offline
Didn't have a tach last 4 years on my 07 until this year. I like the way the bike runs at 3000 rpm. Depending on the speed limit and road, I will shift to the gear that puts it at 3k on the tach. On the interstate 3k is 80 in 6th gear.
  #44
Old 09-24-2011, 09:03 PM
Timmy B's Avatar
Timmy B
Timmy B is offline
Location: 12 year, Colombia, 4 years Mexico, currently In Kuwait, but Boston is HOME!!
1st to 2nd 0 - 20,25
2n-3rd depending on trafic 25-40
3rd to 4th 40-60
4th - 5th 60 -75-80
5th to 6th 80 -100
I love to rev the bike but once at speed I will adjust
  #45
Old 09-24-2011, 09:58 PM
Then Came Bronson's Avatar
Then Came Bronson
Then Came Bronson is offline
Received 2,070 Likes on 777 Posts
I read the manual back and forth a couple of times but following those guidelines the motor sounded like it was lugging so I put off shifting for another 5 mph or so.
Jon,
Go with your instincts.
You said it sounded like the engine was lugging at the recommended shift points written in the manual. That's because if you're shifting your bagger at those recommended points, you're driving your Harley like my grandmother would…and she's been dead for 40 years.
Cruising around in 6th gear at 55 or 60mph is ludicrous. I don't even know what the rpms would be going that slow in 6th, but I imagine it would be somewhere not too far above idle. Your gut instinct of at least 70mph is a good starting point for 6th gear. Personally, I like at least 75, but prefer to cruise at 80mph in 6th gear. That way, I'm humming around right on the cam, and can cobb on the power and pull like a freight train at that speed and gear.
Bottom line…it's going to be your call when you're comfortable shifting into overdrive. My advise: ride that thing, and don't be afraid to use those rpms!!!
  #46
Old 09-24-2011, 10:50 PM
Intrepid175's Avatar
Intrepid175
Intrepid175 is offline
My 09 Ultra is right at 2000 rpms in 6th gear at 55 mph. On nice level ground, riding "easy," it'll handle it just fine. Lugging an engine is a function of speed, gearing, and "load!" If the ground is level and I'm gentle enough with the throttle, I can bring it down to 55 mph and accelerate away with no undue protest from the engine. The pre-09's are geared a little higher so it may not work for them but it can be done with my 09.
Having said all that, it is "not" something I make a habit of. Bottom line is, ride the bike in whatever way "feels" best to you. Everyone is different in their techniques, habits, and the country they ride in. I live on the Texas Gulf Coast. Can we say, "Flat!!" I can get away with things that someone in Colorado probably wouldn't. The bike will let you know if it's unhappy. Listen to it!
and.....
Ride Safe,
Steve R.
  #47
Old 09-25-2011, 03:02 PM
mac1911's Avatar
mac1911
mac1911 is offline
I personnaly never use 6th until I hit 75 and am going to be at that speed a while. The motor seems happiest at about 3000 or so. Seems to run cooler, get as good or better fuel mileage and is certainly more responsive there.
  #48
Old 09-25-2011, 07:07 PM
mcain49's Avatar
mcain49
mcain49 is offline
Originally Posted by KCFLHTK
My 2010 Classic with the 96" would not do 6th gear at 55 very well at all. However my 11 Limited with the 103 has plenty of grunt to pull the bike in 6th gear at 55 mph. I dont see the point of even having a 6th gear if you are only using it above 65 mph.
Have 2010 UC 96" as well and it has never had a problem in 6th gear at 55. Guess all bikes are different.
  #49
Old 09-25-2011, 07:42 PM
peddler's Avatar
peddler
peddler is offline
You're not going to hurt that motor riding 60mph in 4th gear. You're a long way from the red line.
Just curious. How did you know when to shift on your Yamaha.
  #50
Old 09-25-2011, 08:56 PM
iwillfixthem4u's Avatar
iwillfixthem4u
iwillfixthem4u is offline
Originally Posted by one-up
I shift into 6th on my 2010 Street Glide 96'' at 60 MPH. I even let it drift down to 55 MPH. The engine rpm is at about 2,000 at 55 mph - much lower than 2,000 (or 55 mph) and it begins to lug.
My $0.02
same bike and same findings +1
Quick Reply: 6th gear speed/rpms?
