anything I should look for
Have your dealer inspect them. That's alot of miles if they haven't been replaced already. Had mine replaced at 45,000 and there was little left of the inner tensioner. Would not have made it through the summer without having them upgraded. An inspection will let you know where you stand with this motor. Important to know.
55K is high miles. Cam tensioners should definitely be upgraded to the new,post '07 hydraulic tensioners,if they haven't already been done. They can go bad anytime, but particularly between 20-30K miles. If they go out on you while riding, they can do catastrophic damage to your motor. It is possible the previous owner did the upgrade,as they would've almost certainly gone out by now,but if he didn't, 55K makes the motor a ticking time bomb. The upgrade should run about $600, then you never have to worry about them again. I would not ride until they were inspected by your dealer. This is a known problem that Harley refuses to man up & take responsibility for. Google Harley cam chain tensioners for the full story.
They do need to be checked, but many have gone this far & further, I had a 99 that had 76K on it before I decided to do performance mods, the tensioners were less than 1/2 worn, the second set went 60K. It is a crap shoot as to when they will die, but as said they can do major damage when they fail. The SE upgrade kit is well worth the money as it also includes an upgraded oil pump.
