Quick question about Primary oil level??
I'm tracking when you change the primary fluid you add the amount the manual says depending on year and bike model and as a rule of thumb if you can't see it after adding the correct amount add more until you can see it through the derby cover with the bike level not on the kickstand, and never put so much in that it goes over the bottom of the clutch spring ( I use to think it had to reach the bottom of the clutch spring but was corrected by an old biker years ago that it doesn't, it just can't go over it).
My question is, after helping a buddy change his fluids we added and checked everything and all was good. When we filled his primary with the required amount as per the owners manual it was visable and just about at the bottom of the clutch spring but not touching. Sealed everything up and sent him on his way, I noticed when he got on the bike it dropped quite a bit and he has it lowered 1". Seeing how far his bike sank made me wonder if we might have added to much oil in the primary? I'm not sure how far over ther the clutch spring it would have been over but I'm sure it is. So I was wondering if maybe I should recheck his Primary levels with him sitting on the bike? Any of you heavier guys with lowered bike ever run into any trouble with the clutch slpping by having to much primary oil? I know it will still work but I don't want his clutch life reduced because I added to much oil. Anyone know or have any help for me on this so I can fix it before it might become a problem? Tried a search but nothing to do with this was found. Thanks |
this is the first time I have ever heard of rider size/weight having anything to do with fliud levels on a bike. Lowering either, I don't think it makes any differnece, as long as you are filling to factory specs...just my 2c
I think your over thinking this
this is not a crucial measurement.
the clutch plates need some lube to work ( new plates are soaked in lube before install) fill to the bottom of edge of the clutch basket ( bike on jiffy) and go Mike |
Okay, I just didn't want to be the reason his clutch went out.
Mine and his softail owners manual clearly stated to check the fluid level while the bike was level not on the jiffy stand, but the correct amount was added. Thanks for the replies |
That makes no sense. When you sit on the bike the whole bike drops not the clutch within the primary?
Originally Posted by JohnFlorida
(Post 9142107)
Thanks for the help |
Some will say only a quart after change (not removing primary cover) I add 38oz's and if I don't my se compensator will make noise at 50 mph and up.. I have no issues getting in neutral and comp is very quiet going down road however it and the chain is a bit noisy when cold and rapp'n some r's... BTW that is not with bike on jiffy stand that is bike standing straight up the oil level is to the bottom of clutch basket that is how I do it on my bike..
Just put in the amount called out in the manual and dont worry about it. the amount does vary by models and year.
© 2024 MH Sub I, LLC dba Internet Brands
