led oil dipstick
I have one, the newer style. The early ones were a problem. No problems with the second one. I have fould it to be very accurate for both temp and level. I do remove it and put the stock cap on when washing and its a good ide not to lay it on its face and allow oil to lay on the back side.
Thanks everyone for the input.. Will most likely try one ..but no ..not in place of regular checks.. Just looking for something if i'm out on a long ride ,make a stop ,i can eyeball it instead of trying to stick my hand between the pipe and motor when it;s warm...just for ..a piece of mind thing,,
Received 70,909 Likes
I think that there is no substitute for a manual hot check.... BUT... if you have the HD approved digital dipstick, and you are under factory warranty and/or have the extended warranty, then it would seem that you could use that as "back-up" to prove that you regularly check your oil level before and after every ride.
