Iron Cross or Aftermarket
Couple of things to throw back at you here. I do like my music and about a year ago I bought the hog tunes 3 for the freeway system. I know it is called something else these days but still the same package. The system came with the amp, new front and rear speakers, fairing lowers and the hog pod tweeters. I play my music mostly through my Zumo GPS which has a built in MP3 player and or CD's off the HK stock tuner, so my questions are will these aftermarket systems and handle bar control kits still work with my hog tune setup? I liked that system for Hog Tunes because it was all plug and play into the original Harley connectors. Second question is I have been on the biketronics site and the head units I see have USB ports and IPOD setups which I have no use for. Where else can I find tuners for my Ultra Classic? One last thing also do these aftermarket radios hold up with all the vibration going on. I've been told by many that this is why the HK fails and if so why would aftermarket be any better.
Suggestion: Check your fairing and speaker brackets for breaks. Even if you go aftermarket, broken brackets are a problem.
Suggestion: If you're happy with what you had, send the unit to ICA for repair.
Suggestion: If you go aftermarket, you will probably need to re-wire the HT equipment you already have.
Good luck with your project.
Carl
Carl
Also, if I understand correctly, ICA sold you a unit that was later determined to be defective; promptly replaced the unit with a good one; and, now you're expecting a full refund because you decided not to purchase the product? If true, please don't buy anything from me that I may list in the HDF classifieds or on ebay (where my username is golftours).
Enoy your new tunes.
Carl
If you talk to Tony at Iron Cross Audio, he'll tell you about repairs he's made to aftermarket head units with mechanisms that suffer vibration issues installed on our HD's. Not saying that will happen with your specific product.
Carl
Carl
Having the same issue with my HK.
I'm going aftermarket and considering having Iron Cross service my HK and sell it to offset the purchase of the aftermarket radio.
I went with the Sony DSX-S210X HU, this unit appealed to me for the Tune tray and Pandora capabilities.
For the install I purchased the Hawg Wired Universal kit. That way I can change brands down the road if I choose.
For speakers I'm swapping out the J&M 7.25's for the Hertz HSK 165 components. I'll mount the tweeters in the upper two gauge holes. Going to lose the air temp and volts gauges.
For an amp I'm already running the Elf 2125X, this is very similar to the Arc and J&M amps and seems to put out some good clean power.
Should have everything delivered and installed by Wednesday night.
I installed "just" the Sony HU today and I'm getting humming noise from the J&M speakers. I didn't change any of the amp connections or speaker wiring with the exception of using RCA inputs from HU to amp rather that line in connection.
The noise is pretty strong and not affected by volume or music source.
Any ideas?
Any input would be appreciated
Any ideas?
Any ideas?
Are you running your RCA's or Remote/Amp power on lead (blue wire) near the power and ground wire running to the amp?
