Hidden antenna?
I am a new member long time reader first time poster, i bought the hidden antenna from harley so i can mach my tour pack quick disconnect, well after installing the radio just scans and never stops if i hit one of me presets it comes in but has a lot static any help??
check and make sure connections are correct first.. ensure no wires got pinched or grounded out... I had a powered hidden antenna on my SG... reception was crappy. Took it off.
There is a thread around here where a guy reversed his antenna mount and ran the full size antenna along side the left side of his bike. I tried that and it works! Antenna is hidden and no loss of signal to radio. I secured my antenna to the frame with two zip ties...can't see the antenna but it works. |
I tried the hidden antenna and removed it after a couple of weeks. The reception is terrible.
I could only get about 3 FM stations and those were all static and fading in and out. I put the shorty antenna on and it works great. I just listen to cd's now when I remove the tour pak |
yes everything is where its supposed to be and my radio sucks now!! thanks boom audio for 40 bucks wasted i will do that with my antenna now
The problem is in becoming a texter; i.e. no capitalization or puctuation. Just kidding.
Suggestion: Post a picture or two of the installation. You wouldn't be the first HDF'er who was convinced the installation is correct only to discocover later it wasn't. Carl |
I have the boom audio internal antenna and it works great. Picked up local radio station 70 miles away.
dparker747 where did you plug in the power and ground?? and on the inner fairinf did you place the antenna?
Harleypingman i could have it done wrong i am not against that at all my wife says i do everything wrong |
Originally Posted by FINALEFFORT
(Post 9544212)
Harleypingman i could have it done wrong I am not against that at all my wife says i do everything wrong |
If the little red light on the antenna doesn't come on with the ignition on..... you don't have it wired right.
i didnt not plug into the back of the cig lighter? that has to be my problem? but the red light it on??
© 2024 MH Sub I, LLC dba Internet Brands
