Little Help with Tour Pack Hinge install
Great thread learned 2 new words/phrases above today.
Instructions say to do base first. Works great to rest lid on hinge when attaching.
I had the dealership put on those premium hinges
awhile ago. Well I am not sure if they installed them right but her's developed a small
crack at the front hinge. So I told her to take it easy when opening it and closing it.
Well the 1st ride we did after I found it (only a short 20 miles) it got worse. It now
is about 4" long vertical. When I took off the lid I noticed they did not enlarge the
holes for the screws. The holes have screw threads in them and I wonder if that
helped start the crack in the first place. I wonder if the threads caused undue stress
on the lower tour pack from vibration to cause the crack. I am taking the whole
tour pak off today and have an idea to repair it. Going to put a big plate on inside
with two bolts drilled thru lower tour pak on either side of crack to hold it in place.
Then drill new holes thru plate for hinge. It will greatly enhance the lower hinge
support. Does anyone have their original instructions from putting on the Premium
Hinges ? I would like to know "IF" they were suppose to enlarge those holes on the
lower tour pak.
Rob .....
lower tour pak.
Rob .....
If they don't replace it, whoever fixes it must drill a small hole at the end of the crack or otherwise the crack will keep growing.. If you do this make sure you are at the end of the crack as hairline indications can be hard to see and you have to be at the end of the crack for this to work.
Those thread screws in the plastic are the identifier to the problem as the installer obviously screwed the fastener into a hole that was too small, thereby expanding the plastic and inducing the crack.
I would go back there and spew all over them for a replacement...
hole which they did not. So having that info I called the owner of the
dealership and told him what I found. He said no problem and to bring
it in when I have a chance and they will replace it NO CHARGE.
They have always been great to us so I was not surprised by his answer.
BTW ... Dealership is American HD in Leominster, MA
Rob ......
Ss69camaro7
General Topics/Tech Tips
12-15-2018 12:54 AM
