Tuners and Fuel Mgmt Systems
Ok guys, don't hate on me too much, but I am an idiot when it comes to these things. Here are my questions...I'm gonna get some Wild Pigs slip ons for my '11 RK. I gutted the cat over the winter, keeping the stock header pipes, and I'm gonna get a SE Heavy Breather. I know I'm gonna need to do a download with one of these systems after my upgrades, but should I just buy one or just have my stealership do it?
If I drop the cash on one of these, will I be using it more than just the one time for said mods? And wtf are xieds, and sert? Doesn't seem worth the big $ for one of these if I'm only using it the one time. |
The Plug-n-Play FL-XiED-10 richens the Air Fuel Ratio from14.6:1 to 14.0:1 in closed loop mode.
http://www.dkcustomproducts.com/FL-X...XiED-10-NR.htm |
Originally Posted by Harleydaddy
(Post 9795200)
I just went from the SERT to a Zippers thundermax Autotune with my rebuild. Price was worth it for me, if it does what it says. Every one in my area including my Indy wanted an arm and a leg to tune the SERT and if anything gets changed your back again. He mapped the zippers on install with my top end rebuild. He says I should never need to pay for a tune again! We will see.
Originally Posted by Sallyman
(Post 9795446)
If this is the only mod you are planning then get the dealer download. Most people that use tuners like SERT(screamin' eagle race tuner), power commander, fuelpak, TTS, thundermax, etc..., like the flexibility to add/remove/change mods without getting a download at the dealer. In lots of cases a "canned" map will do the trick (a map designed for your setup) or most will get a tune on a dyno and build a custom map for their bike. Like I said, if you plan on leaving the engine alone just get the download and be done of it but if you're like me and most other riders on here that can't leave their bike alone then get a tuner!
© 2024 MH Sub I, LLC dba Internet Brands
