Who Installed Passing lamps on FLHX 06-07
RE: Who Installed Passing lamps on FLHX 06-07
I installed the same passing lamp/turn signal bracket on my '04 EG and can't add anything to the wiring question. But the passing lamps are attached to the bracket with a threaded hollow bolt that the passing lamp's positive wire passes through (the lamp is grounded to the housing)and is threaded through the bracket. That bolt (attached to the chrome lamp housing) is secured to the bracket with a nut. You will need a slotted socket or offset box end wrench with a slot(I will check but I believethe socket/wrench is7/16") in order to tighten the nut, otherwise the wire will be between your socket/wrench and the nut--not good.
A friend simply used his grinder to create the slot ina sparesocket for me. Rather than ratcheting away, turn the nut about 1/2 turn then reset the socket on the nut and repeat the process until it is tight. If you just ratchet away the thin wire will wrap itself around the socket and the wire will tear in two.
I'll check and post later on the socket/wrench size.
I thought the install was pretty easy. My big hands had a little trouble getting the two bolts out on the bottom of the bat wing but other than that its a plug and play installation. I still need to fix them to work on high beam also. They help with low beam but I think with the headlight on high beam they would really rock. Just my .02 cents
ORIGINAL: bvette94
How do you get the bottom inner faring off? i can pull the lock but i cant get the lower cover off to install the switch. is there a way to install the switch without removing it?
