Garage heaters
#61
#63
The problem with unvented propane heaters is that the combustion process produces a lot of moisture.
A heater such as the Modine Hot Dawg will vent the combustion gases to the outside.
If you only work in the garage once in a while, a portable ventless system is probably ok, but if you spend a lot of time in the garage, you really need to insulate it and install a proper heater that is vented to the outside. You won`t regret it.
#64
#65
#67
I have a one of these 20,000 BTU ventless gas heaters in 650 sqft garage.
3 of the 4 sides are underground but not inuslated. I turn it on about a half an hour before I work in there and its warm enough to work in a t-shirt. It doesn't have a fan so no need for electricity.
It cycles on and off on a thermostat. I have $75 in gas pipe that I installed myself, and bought the heater on craigslist for $60, and for peace of mind I put a $30 CO monitor with digital ppm reading in the garage.
#68
I have 2 17000 BTU electric heaters in my garage. One the front half much like the Fahrenheat Electric Utility Heater and the other one on the back half so I can tailor where the heat is concentrated. I have a bit of an issue with an open flame left alone with my 60 Vette, 87 Grand National and my Harley. A small gasoline leak could be bad.
#69
I bought a used woodstove a few years back that heats both by radiance and by heating hot water or antifreeze. It is big enough to heat a 3000 sq ft. house. I have it in the workshop and it will roast me out of there if I put too much wood in it. I don't have the water part hooked up cause I don't need it. I plan on tearing the shop down in a couple years (or sooner). When I do that I will build a garage with second floor and put radiant heat in the floor and baseboard hot water upstairs. I will also hook it into my hot water heat in the house so I can use less gas.
#70
