21 inch front wheel question
Old 02-02-2013, 07:57 PM
mdanehart's Avatar
mdanehart
mdanehart is offline
Default 21 inch front wheel question
I like the looks of the 21 inch wheel and a 120x70x21 tire on the Electra Glide. My 87 FLHTC need a facelift. I am aware of the low speed handling issues with this combination, but my rear end has also been lowered one inch...Would the above combinations of lowered rear and 21 inch front create an unstable road personality?
Old 02-02-2013, 09:58 PM
Hotrodz_n_Harleyz's Avatar
Hotrodz_n_Harleyz
Hotrodz_n_Harleyz is offline
the more you increse your rake... which is what you're doing when you raise the front/lower the rear, the heavier the steering will seem at low speeds. I don't know, mines fine with the 21 front and stock rear, you may find you need to drop the front end to make it handle like you need it to.
Old 02-03-2013, 09:18 AM
DuraGlide's Avatar
DuraGlide
DuraGlide is offline
Mine was fine with stock front and rear on my 08 SG. Stock SG rear is 1" lower than other FLH's so you should be fine. I now have air ride on the rear and the bike still handles fine with the rear lowered 3" from stock. Low speed steering is a little heavy but I don't even notice it anymore.
Old 02-03-2013, 09:35 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
Many people lower the front end 1" to compensate for the added height of a 21" wheel. It will raise the bike about 1.25". However this is not a necessity. I'll put a 21" on any bike I have and ride it without lowering prior to decide if it is necessary. Much of this really has to do with the riders inseam as many pope have trouble reaching the ground with the feet prior to adding a 21" wheel.
As far s the stock size rear you will be fine with that. Adding and 18" rear will raise the back about 3/4".
Old 02-03-2013, 10:26 AM
mdanehart's Avatar
mdanehart
Yes.... Great for the qualified responses..I want keep the rear lowered one inch using the 16 wheel and now the future 21 inch wheel and 120x70x21 tire...if needed I can always lower the front end, but not if favor at this point..thanks again all ..
Old 02-03-2013, 10:28 AM
fenderzig's Avatar
fenderzig
fenderzig is offline
I did what you did except that I lowered the front end 2 inches. Rides great
Old 02-03-2013, 02:05 PM
pit1600's Avatar
pit1600
pit1600 is offline
mine when she was with 21/16 and 1" lowered suspension front and rear, rode good
Old 02-04-2013, 11:26 PM
tionestat's Avatar
tionestat
tionestat is offline
Default 21"
21 front and 16 rear w/1" lowered in rear. Love it..
Old 02-05-2013, 03:59 AM
mdanehart's Avatar
mdanehart
Tionestat....nice, thanks.
Old 02-05-2013, 04:50 AM
kmayHD's Avatar
kmayHD
kmayHD is offline
1" Lowered rear, stock front, 21/18, no problems here. Rides dynamite on these Metzelers.
Quick Reply: 21 inch front wheel question
