Sealed Inner Primary Bearing?
Old 02-24-2013, 03:30 PM
1987 FLHS's Avatar
1987 FLHS
1987 FLHS is offline
Stage II
Post Sealed Inner Primary Bearing?
Hey guys I have a 1987 FLHS Electra Glide Sport and I am in the middle of a inner primary job. What happened was that my front pulley got loose and I'm pretty sure my inner primary bearing walked out as a result. I am currently replacing the pulley, quad seal, big seal on transmission and was wondering if I should go with the sealed bearing? Has anyone used it and if so did the sealed bearing leak? I have Primo Rivera sealed bearing i was thinking of installing, are these any good? the S&S non-walkable inner primary race is not available for my bike so I guess I can either go with the sealed Bearing I have or go to the Harley dealer and get a new stock race and bearing and seal? Anyone who has gone through this with advice would be greatly appreciated!
Old 02-24-2013, 04:56 PM
BIGRED1's Avatar
BIGRED1
BIGRED1 is offline
I was having a problem with my '95 Ultra after the install of a 113ci motor. The inner primary bearing wanted to walk out and cause a leak.
To answer your question, I went with the sealed bearing and have had no more problems even after 20k miles.
IMO it is a good deal, especially if you need to remove the inner from time to time. In my case, I kept eating the tranny bearings. Bakker fixed that!!!
Old 02-24-2013, 05:41 PM
03dragonRK's Avatar
03dragonRK
03dragonRK is offline
After having two races walk into my transmission I replace them with the Baker sealed bearing and ran it for over 50,000 miles without an issue. It may still be going strong as I traded the bike in on my current ride.
If my 11 starts doing the walk I will do the same. Great product!
Old 02-24-2013, 07:31 PM
Def Mute's Avatar
Def Mute
Def Mute is offline
Got it in mine...
No leaks for last 15K.
Old 02-06-2014, 12:10 AM
b's13flhx's Avatar
b's13flhx
b's13flhx is offline
6th Gear
Sorry to bring up a dead thread, but, does anyone have pictures of the race with the primary cover off. My buddies 92 evo has a tranny leak from between the primary and tranny and from my searching this seems the obvious culprit. The race appears to have walked a quarter inch or so from the tranny into the primary and the seal on the shaft is loose between the race and the tranny.
Thanks
Old 02-06-2014, 09:26 AM
SPECIAL ED's Avatar
SPECIAL ED
SPECIAL ED is offline
Went to a Baker sealed IPB on my 06 Dyna never had a problem after that.
gsequel1
13
05-24-2023 10:03 PM
FroggyFatBoy
47
06-07-2015 05:57 AM
scottdoege
10-23-2011 08:48 AM
gunnert
05-05-2008 08:00 AM
Quick Reply: Sealed Inner Primary Bearing?
