Rear Running/Turn Signals
I hooked up dual intensity lights to the rear turn signals. Here is the problem. The running lights work, but as soon as I attach the turn signals they turn off. The signal works, but the running lights do not unless I unplug them from the signal wires. To recap, the turn signals do not even have to be on for the running lights not to work.
Any thoughts as to why?
Almost sounds like you have one of the lamp leads set up for a ground, should be two contacts on the bulb base, each has a separate power supply, one running one turn signal, the base side wall is the ground side. We made flashing side lamps on the old GM's by adding a lamp inline to the running lamps to the turn signal with no ground, it could also be you are set up with the lamps in series rather than parallel with a poor ground.
There is no bulb. It is LED. It is 3 leads. Green (ground), Yellow (running), Brown (turn).
Here is how it works if I was to hook it up to a 9V.
Green to (-), Yellow to (+): lights up.
Green to (-), Yellow and Brown to (+): lights up brighter.
Green to (-), Yellow to (+), touching, removing, touching, removing, etc and Brown to (+): sold light with brighter light flashing as I touch and remove.
I am hooking it up to the wires under the tail light.
The Green to the main Black wire coming from the 3-plug in going to the tail light.
The yellow to the Red wire coming from the 3-plug in going to the tail light. (AKA running light).
The Brown to the Purple wire coming from the 2-plug that use to go to the old flasher.
When the Green and Yellow are hooked up it lights. As soon as I hook up the Brown (no matter if the flasher is on or not) the light turn off. As soon as I turn on the flasher, it flashes like it should.
It I unhook the Brown from the Purple, it comes back on, If I touch the Brown to the Red it lights brighter. If I touching, removing, touching, removing, etc it flashes.
Something else that I noticed. When I hook it up as described the dash flasher indicator lights up really dim like it is getting a little juice.
