Drive belt hitting crosspipe
Old 03-09-2013, 10:16 AM
DevilSperm's Avatar
DevilSperm
DevilSperm is offline
Default Drive belt hitting crosspipe
I just installed my new jackpot 2-1-2 head pipe and noticed the drive belt was hitting the cross pipe. I disassembled that portion and rotated the cross pipe a bit so it was laying more flat to give the belt clearance. However, once I did that, then my muffler would no longer fit with the angle since the exit of the cross pipe was angled up. I was able to push the pipe down to get the muffler into the crosspipe, but now Im sitting with about 1/8" clearance between the pipe and the drive belt.
Anyone else run into this problem? Im wondering if the exit on the header isnt slightly misaligned causing this issue. I would assume everything is jigged so that cant happen though.
Thoughts?
Old 03-09-2013, 10:21 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,932 Likes on 3,026 Posts
Try loosening all the bolts but leave it assembled, and twist it into position. Just a suggestion.
Old 08-06-2019, 04:45 AM
jaho's Avatar
jaho
jaho is offline
5th Gear
Hi,
I am riding a Iron 883 2014, and I experienced the same issue as you. My mechanic tighten the drive belt in my case. Now the drive belt although did not touch the drive belt, is very close to it.
I thought of dismantling the whole exhaust starting from the engine. But will wait and monitor the belt for a while.
mikeo33y
09-20-2015 07:09 AM
chief1600
09-03-2014 11:31 AM
Bill Murray
05-02-2013 12:22 AM
Beemervet
EVO
08-08-2007 07:19 PM
clayman
10-15-2006 03:08 PM
Quick Reply: Drive belt hitting crosspipe
