Baker DD7 Pros & Cons
Is anyone using the baker 7 speed trans on there touring bike is it worth the $2700.00?
What don't you like about HD's 6 speed?
Originally Posted by ultra5516
(Post 11132075)
Originally Posted by bigdaddy33
(Post 11149392)
I suppose I get the extra giddyup but its very expensive giddyup and a lot of shifting. |
Only thing I think that would be good for is keeping rocket-like acceleration on a high-hp/tq machine and be able to drop your final drive ratio with different sprokets. The additional gears could have a purpose but I'm not sure I see it... I am curious as to others thoughts on this, so gonna subscribe and watch.
The 6 speed in your bike has overdrive 89:1 ratio final gear....5th gear is 1:1
The baker 7 speed is 1:1 in final gear I can't understand why they would make a 7 speed gearset with without a overdrive....why, why, why :icon_nut: All the big HP makers I have talked to said stay with the stock unit. |
Originally Posted by GaugeMods
(Post 11149528)
(Post 11149528)
The baker 7 speed is 1:1 in final gear I can't understand why they would make a 7 speed gearset with without a overdrive....why, why, why :icon_nut: All the big HP makers I have talked to said stay with the stock unit. http://www.bigboyzcycles.com/Gearratio.htm |
[quote=GaugeMods;11149528]The 6 speed in your bike has overdrive 89:1 ratio final gear....5th gear is 1:1
The stock 6spd cruise drive 07 up has a 6th gear of 1:1, same as the DD7. The main reason for going to the 7spd is to get a lower 1st gear ratio, that's why people are going to 30T front pulleys also. The 07-08 1st gear is 9.31, DD7 makes it 10.49. The 09 up is 9.59 compared to 10.81, it makes for a lot less clutch slipping at takeoff & better acceleration. Compare that to the 5spd that has a 1st gear of 10.78. I certainly don't need 7 gears, but that seems to be the only way to get a better 1st gear ratio & still have the 2.875 final drive, that being said I'd love to have one, but there's other things that will get my 3 grand spent on first. If my 6spd ever has problems, or I find a money tree:icon_laugh:, that's what I'll replace it with. |
if I shell out any gears on the stocker. I will have one of these.
I am wrong, I stand corrected, I always assumed the 6speed was a overdrive Tranny, Harley even calls it the 6 speed cruise drive. What kind of marketing crap is that
Looked in my service manual and yes 6th gear is 1:1 my bad Still 7 gears no overdrive? 2700.00 |
© 2024 MH Sub I, LLC dba Internet Brands
