Tire lesson the hard way.
#91
You must not have seen some of the tail chewings given to people who DIDN'T SEARCH for a thread on a given subject. Guys get scolded for not searching, others get scolded for searching. Looks as though you are one that scolds the "searchers". Still winter where you are?
#92
Sticking with Dunlop American Elites
I'm on my 3rd set of American Elites. Great handling in curves, wet weather, etc. and last set got me 23K miles (could easily have gone another 3-5K without concern). I know this is an old thread but so what.
Another factor is that I use Ride-On for dynamic wheel balancing, so no weights on my chrome wheels. 1 tube in front and 2 in the rear. Great stuff!
#94
So I read this thread and started checking load settings. Most front ones are 500-600 and rear is 900-1000 load rating. So my bike is 800lb and I'm 200lb So thats already 1000lb. Am I thinking this correctly? Or is it split between the two tires? I'm sure theres less on the front but what load do I look for on the bike for riding 2 up most of the time?
#95
Back in the spring I chose to put new tires on my 04 RK. The local tire shop recommended Michelin Commander ll tires, and gave me a good price so I went with them. From day one I knew these tires made me feel a bit uneasy but couldn't really figure why. Long story short, I'm going back to the factory Dunlop tires after finding that the Michelins aren't load rated for the weight of my bagger and I was getting sidewall flex that gave me a ride like I was on ice. Now, too late, and more $$ spent for a tire lesson I've figured how to shop for the right tires. The Michelin Commander ll tires may be fine for a sport-lighter weight bike but not for a heavy touring model. BTW, I had replaced my old Metzeler 880's with the Michelin's, and the 880's gave me over 25k miles when I took them off.
#96
Use the pressures recommended for your selected tyres for riding solo. Add a few extra psi to the rear tyre for adding a passenger and about half that extra to the front. Hope that helps!
#97
#98
#99
#100
Interesting write up. So that makes the bike with me on about 624 lbs on the rear and 416 lbs front. That makes a lot more sense. But with luggage and passenger I'm about 825 lbs on the back.
So all 3 of these have the same load rating.
Commander II and III is 1019 lbs rear tire
AE is 1019 lbs rear
AE is 1019 lbs rear
