Replace 255's in 2013 Road Glide
I bought a 2013 Road Glide Ultra and let the dealer do my upgrades. (enough said?)
They installed a fatcat 2-1, S/E-A/C, S/E tuner, and 255 cams. Dyno tuned and I don't really like it. I was told that it needs a good tune.
If I am going to do that then I think a better cam would be needed also.
Mr. Wood said a 222 would work great for 2 up.
I would like to know which cam would give me the best performance? 50* 2-up
The 255's do fine then fall off quick.
Any and all advice needed.
Thank you
Thank you
Thank you
Thank you
Sent from my Galaxy Nexus
Thank you
Thank you
Steve really knows the V-Twin well and can create a great engine combo for you. He also is well-known for his tuning ability.
I too had the 255's by the dealer and changed over to a kuryakyn cam and results have been stellar.
All of your other components should work fine with a better cam. I personally think the D&D 2-1 is a little loud especially for long rides...just my opinion though.
Give Steve a call...nothing to loose.
Just done a 103 kit on my 08 RG and done the 255 cams. I am sure the woods will pull out a little further but the 255's do fine for me. I would say the 255's fall off in the upper 4000 rpm. range. I road 1600 miles one way to strugis this year and in 6th gear at around 70 mph and was turning like 2650 never seen 5000 rpm the whole trip. So i guess i got the cams i need for the way i ride my bike. Hey but if some one want to buy me a set of wood 222's to try i would not mind. And when i decide i want to go faster i guess i will buy a bike that is made to do that. You know for what a 131" motor cost you can buy a BUSA for about the same money and really go fast so it don't add up to me.
Depending where you are in Texas it would be worth a visit to GMR Performance in Ft. Worth, Tx.
Thank you
Thank you
I talked with him when i did my 95 then again when i went 107. My 408G cams from him kick a$$ and make huge usable power. The valve train is a little loud, but it has quieted down over time, or i have gotten use to the noise. Either way, IMHO, you got great advice on cams.
