ape hangers on 2014 STREET GLIDE
Old 07-06-2014, 02:53 PM
petdoc94's Avatar
petdoc94
petdoc94 is offline
That is a big pill to swallow.....Better yet maybe bend over and take the stick may be in order..
Old 07-07-2014, 09:17 AM
DesertDweller's Avatar
DesertDweller
DesertDweller is offline
I did the WO 12.5", I replaced the cables as I wanted the stainless. I did not get the heated grip extension I just soldered longer wires.
Here is the parts list I used:
Mfc Part Description
Wild 1 WO577 Wild 1 12.5 handlebars
HD 37200040 HYD CLUTCH LINE,DIAMONDBACK,76.50IN
HD 41800321 BRAKELINE,UPPER MID,ABS 12mm Bore 64” to Puzzle box
HD 41800425 BRAKELINE,UPR,FL,DIAMONDBACK,28.0X0DEG 10Mm Bore
Namz NHCX-J08 8" Extension w/Matching Wires, 2011-Up Softails, 2012-Up Dyna & ALL 2014 Models except V-Rod.
File Type: jpg
Old 07-07-2014, 11:57 AM
SALBEEZY's Avatar
SALBEEZY
SALBEEZY is offline
JSR is doing bars for the '14's up to a 20" rise awesome prices too!!!
http://www.jsrcustom.com/PARTS.html
Old 07-07-2014, 12:02 PM
MisterGrumpy's Avatar
MisterGrumpy
MisterGrumpy is offline
Stage IV
Yaffe now makes bars guaranteed to fit a 2014.
The trick isn't so much finding the bars, it's getting them to fit the larger fairing, at where they clamp
The clamp portion of the bar needs to be wider to accomodate the new Boom audio system, and I went through 4 sets of bars to be able to get them to fit right.
If you're handy, nothing a dremel couldn't fix though
Old 07-08-2014, 12:15 AM
SERGDOG's Avatar
SERGDOG
SERGDOG is offline
Did you guys solder your throttle sensor wires??????
Old 08-02-2014, 08:08 PM
rockymtman's Avatar
rockymtman
rockymtman is offline
Default 2014 street glide 12.5 " wild 1's handlebars
Hi all -
I had these on my 2008 SG. With new updates on the 2014 I can't find 2 dealers that agree on all that is needed to install. Wild 1's themselves are the best tech source I have found. I am going +6 on clutch and brakes lines. My problem is getting the dealer to know if I in fact need wire extensions. Some say yes, some no, Wild 1 says yes.
Anyway, bike is going in on Aug. 4, if it is done in one day I will be thrilled and shocked because of this confusion on wire kits.
That being said, Wild 1's to me are the best because of their tech support and quality of their bars. BTW, of all the things I have put on bikes over the years, these bars are by far the best investment I've ever had. They literally make the bike feel like it has power steering!
If anyone knows for sure if wire extension kits are needed, please reply. Thanks.
2014 SG
Vivid Black
V&H Blackout Round slip-ons
V&H Headpipe - black
So to be 12.5" Wild 1 WO577 bars
Arlen Ness air cleaner
Old 08-02-2014, 08:44 PM
Railridin's Avatar
Railridin
Railridin is offline
Originally Posted by rockymtman
Hi all -
2014 SG
Vivid Black
I put the 12.5 on mine about a month ago, the clutch and brake cables reach fine, having hd do the install is a HUGE waste of money if you can do it yourself with basic tools and a service manual. On a scale of 1-10 difficulty it's probably a 3 or 4.. Google namz extensions. That's the only thing actually needed for the install. I went with the 12" I believe.
Old 08-02-2014, 09:18 PM
rockymtman's Avatar
rockymtman
Default 2014 SG 12.5" Wild 1 ape hangers
Any chance you or anyone knows the Namz part number needed for the extensions? Thanks much to those who know.
Old 08-02-2014, 09:48 PM
Railridin's Avatar
Railridin
http://www.namzcustomcycleproducts.com/products/handlebar_extension_kits_2011.html
NHCX-J12
These are what I used.
Old 11-11-2014, 12:28 PM
Ibrown70's Avatar
Ibrown70
Ibrown70 is offline
3rd Gear
Default 12.5 apes on 2014
So the stock cables on the 2014sg ,(brake and clutch) reach fine with 12.5 apes. I'm want to order mine and just want to make sure I can use stock cables. I already ordered wiring extension. Thanks for any info !
Quick Reply: ape hangers on 2014 STREET GLIDE
