One Cylinder Shutting Down
I guess I'm probably looking at a trip to the dealer since I don't know of an Indy anywhere around this one horse town I live in. And this could probably be put in a better forum but I am having trouble with a tourer. One cylinder shuts down when it gets warm. Was out riding Friday and was about 80 miles from home when the bike stumbled and then started running on only one cylinder. I turned around and headed home. Went back in third gear wide open and could barely make it up some hills. The engine displayed all the way.
I remembered I bookmarked a thread about codes so followed that to display them once home. I can't tell which code is current without clearing them and don't want to do that so the dealer has everything about what has happened.. But here are the codes. P0131 which my list says in front O2 low or lean. P0151 which is rear O2 low or lean. And P1351 is front ignition open/low EFI. It says that PN 34455-07B is the module displayed. I think that's the Stage 1 download but not sure.
So is there something simple I can try or is this a get it to the doctor thing? Appreciate any help. It will be Tuesday before the dealer is back to work.
Oh, this is a 2007 Electra Glide Ultra Classic.
So what do you guys think now? Plug wire or a second coil? Or both? Or take it to the Harley doctor? I've never lifted the tank so have no idea if I can even get the tank up far enough to get to the plug wires.
Had a similar problem with my 07 SG . Threw a bunch of parts at it (coil,wires,plugs,CPS,intake seals,etc.) ended up being a broken injector wire. The insulation was holding it together, so it would make the connection intermittently. Break was right at the connector. Turns out HD tie wrapped the wire harness too tightly stressing the wire.
