Melted microfiber cloth onto exhaust pipe
  #31
Old 10-29-2014, 10:13 PM
steelerdude1's Avatar
steelerdude1
steelerdude1 is offline
I use a nickel to remove the big chunks then lube and 0000 steel wool, never a problem. I have removed microfiber, boot rubber and frog toggs, worked every time.
  #32
Old 10-30-2014, 07:37 AM
05UltraBob's Avatar
05UltraBob
05UltraBob is offline
Another trick I have found that works:
When the pipe is hot after the next ride, or that ride if you found it quick enough...Take a wet ALL COTTON clothe and most things melted will wipe right off, then just a little fine polishing once it's cooled down.
It must be wet and must be 100% cotton!!!!
  #33
Old 10-30-2014, 07:51 AM
dochawken's Avatar
dochawken
dochawken is offline
Originally Posted by vbx07
I did the same thing and the only thing that work for me was ez off oven cleaner. Yellow can. Took heat shield off and preheated it with a propane torch, then sprayed on cleaner and let it do the job. Took me 4 tries but it came out perfect! Chrome was unscathed.
+1 on that!!
  #34
Old 10-30-2014, 08:23 AM
roadking2014's Avatar
roadking2014
roadking2014 is offline
heat up the pipes and wipe it off with a wet cotton towel. There will be a lot of steam and heat so be careful.
  #35
Old 10-30-2014, 08:27 AM
hvacgaspiping's Avatar
hvacgaspiping
hvacgaspiping is offline
Received 16,369 Likes on 8,431 Posts
Originally Posted by f7addict
Thanks guys. I didn't have the patience to wait for responses and wore the crime off one section. One New big Louie on order....
Next time use oven cleaner on a warm pipe (no more than 130*). Be sure to spray it on a rag away from any painted surfaces, and then apply the oven cleaner generously onto the affected area and allow it to sit until the pipe cools off completely. It`ll just wipe clean then. No elbow grease needed and above all, no scratches.
  #36
Old 10-30-2014, 09:57 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,526 Likes on 1,421 Posts
WD40 left on a little while and no scratch.
  #37
Old 11-01-2014, 01:31 AM
Melroy's Avatar
Melroy
Melroy is offline
Normally I will let the bike cool down completely before washing or quick detailing, but 2 weeks ago I was in a rush to go to an end of the ridin season party and went to give the bike a quick wipe down after ridin earlier. My luck I dropped a micro fiber towel on hot pipes. Not bad, but for it landing on pipes for a micro second left some nasty stuff behind. I forgot it was there till I seen this post. Gonna try a few 1 or 2 of these suggestions tommorow
MHinSATX (10-14-2022)
  #38
Old 11-01-2014, 05:32 AM
skiddd's Avatar
skiddd
skiddd is offline
I used a finger nail and some Goof Off, it worked...........
  #39
Old 11-01-2014, 09:54 AM
my67pnycar's Avatar
my67pnycar
my67pnycar is offline
Originally Posted by Lakerat
Next time it happens just let it cool off and scrape it off with a razor blade. It comes off in flakes with no damage to the chrome.
DING DING DING, that is the correct answer. Works like a charm.
  #40
Old 11-01-2014, 11:43 AM
Roadflyer's Avatar
Roadflyer
Roadflyer is offline
Scrape it off with a Penny then polish it up.
I know it sounds like a terrible idea but, the Copper is soft enough that it doesn't scratch the Chrome. It took some convincing for me to try it the first time but I'm a believer now.
Quick Reply: Melted microfiber cloth onto exhaust pipe
