While I was installing the new fender skirt on my `15 TriGlide I noticed the rear of the front fender very close to the tire on the left side. The right side had lots of clearance. Anyone else notice this on their TriGlides?
You made me go look at my '14.
On my '14 the space between the fender and tire is the same on both sides. Not sure if the '15 is designed differently, or if there is something out of alignment on yours.
I'm sure others with '15's will go check their and chime in.
I had the chrome front end kit installed before I took delivery so front end was messed with. Maybe something with installation.
don't think there is anything they could have put together wrong to make the fender off center like that but sure is something to worry about . how is the front of the fender ? if the fender is streight and off center on the bottom it should be the other way on the front
Looking at it the front of the fender looks shifted to the right and the rear of the fender looks shifted to the left. Not much clearance in spots. Only have about 30 miles on it, but did not notice rub marks on tire anywhere. Oh well, off to dealer in spring when weather breaks!
