Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tire shine
Old 04-26-2017, 03:28 PM
laabdog's Avatar
laabdog
laabdog is offline
Default Tire shine
Has anyone ever heard that it's not good to put some type of tire shine on there motorcycle tires. And why not, have any of you done it.
thanks
Old 04-26-2017, 04:17 PM
ord sgt's Avatar
ord sgt
ord sgt is offline
It is not advised to put tire shine on motorcycle tires. Too much chance that you will lose traction. A skid is not a good thing. It's like putting ArmorAll on your motorcycle seat. Lose grip on your seat and see what happens. Just too slippery.
Old 04-26-2017, 04:20 PM
J_MOSH's Avatar
J_MOSH
J_MOSH is offline
Friend of mine did it once and immediately regretted it. Actually just told this story at work today. Traction is seriously compromised. Even if your thinking no big deal ill just do my sidewall you may get a small amount out onto the edge of your treads and when you do a hard lean at low speed the tire WILL slip out from under you. If you value the appearance of your bike at all, don't risk scraping one side of it because of tire shine.
Old 04-26-2017, 04:59 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,499 Likes on 4,612 Posts
As soon as that tire gets some water on it, the tire shine will flow to the tread...
Old 04-26-2017, 08:01 PM
laabdog's Avatar
laabdog
laabdog is offline
Thank you
Old 04-26-2017, 08:04 PM
Fearless (old nickname)'s Avatar
Fearless (old nickname) is offline
Default Comet
Clorox bleach or like I said comet to get the crud off then use Clorox bleach old drag racer trick...
I use comet cleanser on old shiney I like the looks. bleach will do the same thing it just cleans the side walls Ride Safely Fred
Hogdoc45 (04-28-2017)
Old 04-27-2017, 07:37 AM
captbob's Avatar
captbob
captbob is offline
I talked with a Dunlop tire tech rep and he advised that shine products interfere with the chemicals his company puts into the tire compound to prevent deterioration from sun and other elements. He recommends not using anything that might leach the chemical they intentionally put into the rubber.
Old 04-28-2017, 06:11 AM
KJB's Avatar
KJB
KJB is offline
I've heard the same thing from a reputable source so I don't use them. However, every once in a while I get one of those deluxe car washes for my car and they put it on because I forget to tell them not to.
Old 04-28-2017, 07:47 AM
ISP-FLHTK's Avatar
ISP-FLHTK
ISP-FLHTK is offline
If tire companies are putting special chemicals in their tires to protect from UV damage they had better start testing more in Florida or putting more of it in there. If you leave a vehicle sitting out all year with tires exposed they won't last down here. Every so often I will hit my tires with some 303 protectant.
Old 04-28-2017, 07:51 AM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,274 Likes on 11,144 Posts
This comment pertains to Trikes:
Not if you use a quality tire shine like McQuires
Also, the rear tires are automobile tires. And they don't lean at all. No reason you cant put shine on the sidewalks. Actually, same argument forvthecfronts. Just don't put it on the tread. I've done this for 30,000 miles, and never had it spread to the tread, nor slip because of shine.
But, I wouldn't even think about doing it on a 2 wheeler.
Use at your own risk.
Fearless (old nickname) (04-28-2017)
Quick Reply: Tire shine
