Hot rod trike
.There are probably a few thousand aftermarket manufacturers that offer custom automotive wheels. First question is do you want to stay with a 15" wheel or go larger? For example, I had Intro Wheels build me a pair of billet 17x7's with the offset I specified and then I fitted a pair of 205/50/17 Michelin Pilots.
Forget going with a wider tire as the factory H-D fenders just don't have the room.
I'm definitely going to modify the fender around the new tire. Contacted Intro Wheels and, depending on the wheel, they run anywhere from $425 to a bit over $500. That's way better than PM at about $1700 plus per wheel.
