Oil Change help
Springer66 (02-25-2018)
I do the same thing, but I have a third ramp for the front wheel. That way I can just back off all three at one time without using a jack again.
For the jack I just have a motorcycle jack from Harbor Freight. I also have a scissor screw jack that will lift 1100#. But it isn't fast enough.
You guys need to buy the low profile oil drain pan from H-D
They also have special funnel that is designed to drain the oil filter into with a hose that transfers the small amount of oil down to the drain pan.
This pan has plugs threaded plugs and once it is full you can use the handy carry handle to take it to your local parts store and donate your dirty oil and then return home with a "ready-to-use-again" empty drain pan.
FWIW, DK Products sells an oil filter relocation kit that mounts the filter near the LH side passenger floorboard. In addition to making the filter easier to change, it helps cool the oil as the filter is farther away from the heat of the engine.
DK Custom - ST (02-26-2018)
Yes, the Oil Filter Relocation Kit will make things much easier in the future and as mentioned, will help cool your oil as well.
Here's a pic of this on Kevin's(the K in "DK") Triglide, relocated under the passenger floorboard-
Here's a LINK to this kit.
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
