Rear M/C Tire on Front of Trike
Ok, yeah I know this has been discussed before. But, it was hard to use search to find the threads. So, for this discussion, and future reference I started a new thread with a more descriptive Title. Here’s one of the earlier threads, that didn’t address my question.
https://www.hdforums.com/forum/tri-g...ront-tire.html
So, I put a lot of the mileage on my TriGlide in the twisties. This tends to scrub down the center rather quickly. I’m close to needing to replace my Michelin Commander II front tire after about 10,000 miles. I’d like to get more miles, without something ugly like a car tire, and keep the great handling that I have with the CII.
I’m intrigued about the idea of running a Michelin CII rear tire (which has more rubber and deeper grooves), in the front mounted backwards. Per other threads, it is reversed because the design of the rear is supposedly optimized for acceleration forces, whereas the front is optimized for breaking forces...which are in the opposite direction. Is this theoretical, and does it really matter on a Trike?
But, by mounting a rear tire in reverse, the grooves that are there to help channel rain water away...towards the rear...would be pointed in the wrong direction. Is this a concern? For those “Front Darksiders”, have you noticed a reduction of front traction, or more of a tendency to hydroplane, in the rain?
Received 3,940 Likes
I'm running a rear tire, reversed, and have gotten over twice the miles out of it than the stock tire. Handles better, and I've had no issues in the rain.
I've heard good things about the Avon too...might be trying that next.
Any advice for the rear?
However, I am definitely planning on trying the Goodyear Comfortred tires you mentioned. Read a lot of good things about them.
frenchbiker (04-10-2018)
I have ran a rear tire for a sport touring bike, in reverse rotation, on the gold wing trikes I’ve owned in the past. Got very good mileage, 20,000 plus. I like the Bridgestone Battle Axe, BT-45 sport touring bias ply tire. I will try it again on the TGnwhen a new front tire is needed. Some GW trikes also run the Michelin Pilot Active rest sport touring tire on front, reversed rotation. Also Michelin recommended the reverse rotation due to water dispersing and breaking ( belt in tires )...
