Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
2010 tri glide help
Old 04-24-2018, 01:16 PM
Eds01's Avatar
Eds01
Eds01 is offline
Stage III
Default 2010 tri glide help
Hi all,
trike wouldn't start. Dead battery.
Put new battery.
Trike starts right up, then shuts right off.
Only code is O2 sensor.
What do you all think?
Old 04-26-2018, 12:57 PM
Eds01's Avatar
Eds01
Eds01 is offline
Stage III
It turns out that the battery in the key fob was very weak. Cleaned and checked all switches. Cleaned and checked all wire connections. Was still acting up. Changed the key fob battery and no issues at all.
Old 04-26-2018, 07:21 PM
mctraveler's Avatar
mctraveler
mctraveler is offline
good to hear..... welcome to the forum.....sorry I wasn't any help earlier
Old 04-27-2018, 01:42 AM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,082 Likes on 3,484 Posts
Be sure you clear the stored codes so you know if something comes up new.
Old 04-29-2018, 10:10 AM
NHBAGGER's Avatar
NHBAGGER
NHBAGGER is offline
I was told by the dealer to change the fob battery every year and to keep a spare in the tour pac.
Old 04-29-2018, 10:18 AM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,274 Likes on 11,144 Posts
FOB will prevent the bike from starting. But, once started, it has no influence on the bike running. That’s why you can accidentally have the FOB in the garage, start the bike and drive off leaving the FOB at home. Then when you shut the bike off to get gas, coffee, or a beer...it won’t start.
PapaBear69
08-07-2018 12:11 AM
mang0
02-25-2013 09:43 AM
mang0
02-25-2013 06:02 AM
Rob.sundstrom@Gmail.com
02-10-2013 02:00 PM
FLHX007
10-18-2011 06:32 PM
Quick Reply: 2010 tri glide help
