2010 Road Glide no fire
Old Aug 6, 2018 | 07:03 AM
PapaBear69's Avatar
PapaBear69
Stage III
Default 2010 Road Glide no fire
I have a 2010 Ronda Glide Custom. It cranks but will not start. Battery is plenty strong and fuel is getting to both cylinder. I have pulled the plug wire and put a spark tester in place. I am not getting spark. Where too next?
Any help is appreciated.
Old Aug 6, 2018 | 11:54 AM
pdog75's Avatar
pdog75
6th Gear
I would check the Crank Position Sensor on the bike next.
Old Aug 6, 2018 | 07:59 PM
mmesa005's Avatar
mmesa005
Any Trouble / DTC Codes? https://www.fuelmotousa.com/p-29661-...es.html#pcodes
Double check your ignition fuse as being good
Does your bike have an alarm and when was the last time the FOB battery was changed?
Old Aug 7, 2018 | 12:01 AM
PapaBear69's Avatar
PapaBear69
Stage III
Will Check crank position sensor. All fuses are good checked them first. Alarm FOB will not allow engine to crank if not detected. Battery is new. Replaced after checking fusses.
Old Aug 7, 2018 | 12:11 AM
PapaBear69's Avatar
PapaBear69
Stage III
Thanks for fault codes. I will check to se if there are any presnt.
Justin Kelly
Sep 13, 2023 07:38 PM
Eds01
Apr 29, 2018 10:18 AM
DrRich
Nov 25, 2017 07:34 PM
Dave Jazz
Nov 13, 2014 11:49 PM
FLHX007
Oct 18, 2011 06:32 PM
