P1003 code
Old Jun 11, 2017 | 11:07 AM
Justin Kelly's Avatar
Justin Kelly
Default P1003 code
Hey all, rode yesterday, made couple stops was getting on interstate bike started cutting in an out pulled over and bike will not start. 2010 Street Glide throwing p1003
checked all fuses, kill switch in run tried switching around relays. Still nothing. I can't hear fuel pump kick in when I turn ignition on. Could low voltage on battery cause this issue? Any help would be appreciated. Thanks
Old Jun 11, 2017 | 11:37 AM
mkguitar's Avatar
mkguitar
what does your voltmeter- AT the battery read?
p1003 is system relay contacts open- that could be a historical fault- so clear that.
if it reappears then we look at that relay and why maybe it is open
you have to be methodical-
Mike
Old Sep 12, 2023 | 08:36 AM
blown alcohol's Avatar
blown alcohol
I know it’s an old thread
BUT
i am having the exact same problems and can not figure it out
has anyone experienced this? Please let me know
I am being told it’s an ECM issue. I am not sure that is it
Old Sep 12, 2023 | 09:40 AM
memphisharley's Avatar
memphisharley
from a google search it was a system relay
https://estore.chester-harley-davids...ck-p67526.html
Old Sep 12, 2023 | 09:59 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
It seems odd that P1003 doesn't cause more codes. If the contact is open then there is no system power.
On a Sportster it reports that the fuel pump and injectors aren't getting power as well.
To test a relay it needs to be on the bench. Energise the coil and then check resistance of the closed contacts. It should be as near as not zero ohms.
Old Sep 12, 2023 | 10:18 AM
blown alcohol
All 4 relays has been changed
3 relays and the high current relay
Old Sep 12, 2023 | 10:24 AM
Andy from Sandy
The output of the system relay also goes to the ECM - System Relay Power. If you are getting the code but everything else is working with no other codes see if the voltage is missing or intermittent on that pin. Pin 52 connector 78.
Wiring diagram here - 99949-10_en - 2010 Wiring Diagrams | Harley-Davidson SIP
Old Sep 13, 2023 | 07:38 PM
blown alcohol
I just got back from a long road trip picking up a new ECM
Soon I will know if this solves the problem
jpnieuws
14
Jun 8, 2019 09:07 AM
Crey
Mar 27, 2018 11:06 PM
Tim Woody
Sep 18, 2016 10:35 AM
dking420
Mar 27, 2009 01:27 AM
