Floorboard bolts on a Tri Glide Ultra
The ones on my '18 were also very tight when I removed them.
I'd try using an air impact gun before I'd use a large ratchet or breaker bar.
Just a tad each way (in and out) at first then gradually a tad more once it "breaks" loose.
Once you get the bolt removed, wire brush the threads on the bolt and go easy on the Loctite when re-installing.
I went with Tall Boys Cycle floorboard extenders because they not only moved them out but lowered them. At 6'2" it made a big difference in my riding comfort.
https://www.tallboyscycles.com/
