U-Haul Trailer Rental
Morning all,
Need some help here. I've got to trailer the trike about 200 miles north after the mods are done. We are going up to Doc's Performance TTS school for two days and doing the V-Tunes on the Trike. I can not find a ramped enclosed trailer. U-haul offers two ramped open trailers one is 9'2"L and 4'9"w with a 4'9" ramp. The other is 12'L and 6'2"w also with a 4'9" ramp.
With my bike being 40 miles north, I can't measure it. Stopped by the local dealer yesterday tape in hand and they do not have a Tri in stock. Any ideas or help would be appreciated on what trailer will work. I need to get a reservation made. I would prefer using the smaller of the two if she'll fit. The length is not a problem, it's the width I'm concerned about. Both trailers can be viewed on U-Hauls website. Thanks in advance.
Buddy.....
Buddy.....
Morning all,
Buddy.....
Buddy.....
Go with the wider and longer of the two. Your Trike is about 53"+ wide at the rear wheels. Unless you have a side exit door you will be climbing over the top of your bike to get out. Also, I don't know how low the ramp on your trailer is, but you might drag your pipes if the angle is too steep. I have a 6 X 10 enclosed trailer to haul my Trike and mine doesn't have a whole lot of extra room.
T
Edited to add... Sorry Buddy, I misread. My above comments applied to a enclosed trailer and you asked about an open trailer. I'd still go with the longer and wider of the two.
Simply because the base map is in the bike, but the V-Tunes need to be done. I'm not burning up a new engine and you can't dyno a Trike without special equipment that no one has here. That's why we are attending the masters school, to learn how to do this on the road without a dyno.
We'll order the larger one and still may need 2x10's to get her aboard. Not worried about loading as my property is not level and we can load almost straight on. Just don't know what we'll run into once we get up there.
Thanks for that tip, never though about that. We reserved the 12x6 it will handle alot more weight than the trike. Not worried too much about loading here, just unloading and loading her up again at Doc's. Dealer brought mine home yesterday after the mods as a courtesy and to beat the weather. I've got to call them in a minute. Don the driver told me they might let me borrow their open for a couple of days. They also have an enclosed, but the trike won't fit in it.
