Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
BAL Install
Old 10-26-2014, 11:23 PM
jlgale's Avatar
jlgale
jlgale is offline
Default BAL Install
Do you need to take the rear tires off to install the BAL brakes? Thank you in advance!
Old 10-27-2014, 11:00 AM
joe momma's Avatar
joe momma
joe momma is offline
.........I don't know what BAL brakes are...but I am thinking if you do any rear brake work on a t/g....yes,,,remove the wheels..
Old 10-27-2014, 12:25 PM
jlgale's Avatar
jlgale
jlgale is offline
They are Bright *** Lights (BAL). I bought the brake lights from them and trying to figure out if I might be able to do the install. I'm not mechanical at all but I was able to install the Truck Light Phase 7s on my bike. For me that was a big deal.
Old 10-27-2014, 02:14 PM
Redcrow's Avatar
Redcrow
Redcrow is offline
Go for it. Plug and play�� but I took the one off my 09SG only to find I can't use on trike because they changed the way they are made now. Make sure both are same!
Old 10-28-2014, 03:05 PM
screwball's Avatar
screwball
screwball is offline
IF the lights came with an adapter / splitter plug hook up should be easy. HINT, there are 2 plugs under the seat that look the same. The one you see right off the bat is the WRONG one. There is another just under the metal bracket that connects to your break lights. Plug/sockets look the same. If you hook up your lights, and they don't light up, chances are you got the wrong socket.
Good Luck!
Old 10-29-2014, 05:12 PM
scooty's Avatar
scooty
scooty is offline
Thumbs up Bal
I put them on my TG and they are worth every penny ! ! ! yes they are plug & Play each light is separate easy to install YOU'LL LOVE EM ! ! ! ADDED SAFETY is G@@D
Old 10-29-2014, 06:32 PM
fmgsr's Avatar
fmgsr
fmgsr is offline
No wheels come off. Just take the two screws from the original lights out, take the light off, unplug it. There is one plug to the light. Replace the original gasket,
Install both lights. Then read the instructions on the three levels of brightness, then you set the pattern on the Lights. Simple job.
jlgale
Electrical/Lighting/Alarm
10-29-2014 12:19 AM
Johnnyh14
09-21-2014 04:44 PM
relli
01-25-2010 10:47 AM
Boxer 6
03-23-2009 02:36 PM
AdrianVall
12-14-2008 05:00 PM
Quick Reply: BAL Install
