What are the "must do" items for new trike?
#41
Received 3,954 Likes
The Tri-Glide Lift Kit & The Comfort Lift Kit replaces the stock shock mounts of your Tri-Glide. They both give an increase of 1.25" at the shocks and 1.6" at the rear of the bike.
The difference between the two is that The Comfort Lift Kit also slightly changes the angle of the shocks rearward on the swingarm. The suspension now absorbs more of the smaller and larger road imperfections, resulting in less of the bumps being passed on to the rider and passenger.
Net result is a Smoother, Plusher ride.
The Comfort Lift is better unless...the rider/passenger/luggage combined weight is 540 lbs or greater. If this is your situation, it is better to run the Standard Tri-Glide Lift Kit.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
#42
What is the difference between a Tri-Glide Lift Kit & a Tri-Glide Comfort Lift Kit?
Thank you, great explanation.
Does the kit void any warranty?
Forgot to add: any aftermarket products for the steering?
#44
One of the first things I did was contact SeeThroughBraz and got their protective film for my TG.
www.seethroughbraz.com
GREAT product and does the job.
8~\o
8~\o
#45
Fearless (old nickname) (07-26-2017)
#46
I just bought a 2015 tri glide with 2300 miles. My wife noticed a "sway" when we rode.
I notice a slight sway and checked tire pressure and found it high so I am lowering in steps to see if it helps andit has but the sway is still there albeit much less. Has anyone else had this issue?
Drop rear tires to 21-22 lbs and run 36-37 in front tire and see how it handles, those are the pressures I run in our Triglide. Welcome to the forum Fred
#47
The following 2 users liked this post by joe momma:
DK Custom (10-10-2017),
#48
The first items I would suggest would be lights to be more visible. I have BAL tail lights and just ordered Custom Dynamics lights to replace my front turn signals for better visibility for cars coming at me.
Then go for comfort. I changed my seat and added 2 + 2 handlebars so that the trike feels like it fits me. Also added highway pegs for long distance comfort. Then there's the DK comfort lift for the boss on the back. A back rest and drink holders for front and back to cruise in comfort. If you ride when its cold out, don't wait for the winter to add connections for your heated gear.
Last is the bling stuff. I added a DK 2" deluxe tank lift and also cooling deflectors for in front of the tank.
I didn't realize how much I've added to the trike until I started listing it. And I'm sure I've missed some stuff. From all the help on the forum here, are you getting an idea that you can add on forever and still not have everything?
#49
#50
Here is a LINK to a Tank Lift that fits your 2018 TG.
It gets the tank off the top of the engine, letting more air flow over the engine, keeping it cooler.
Also shows more of the chrome you're paying for, and makes it easier to clean.
Reduces buffeting...a lot of the air that usually comes over the top of the tank, hits you in the chest, and then buffets your glasses and/or helmet, is now going over the engine instead.
