Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Replacing Differential Snap Ring Question
Old 08-26-2016, 06:41 AM
46FL's Avatar
46FL
46FL is offline
2nd Gear
Default Replacing Differential Snap Ring Question
Pulled the differential out, snap ring was gone, removed the pulley side bearing and...the pulley comes off without having to use a puller(per manual). Is that a problem? I'm waiting for the local HD dealer to get the snap ring in to install, but not sure about the pulley fit. Concerned about putting this back together without an interference fit on the pulley. Could use an opinion. Thanks
Andy
mud
04-07-2021 04:19 PM
quilla
2018+ Softail Models
13
03-27-2019 06:26 PM
P'colaHarley-17RGS
12-29-2008 10:13 PM
Quick Reply: Replacing Differential Snap Ring Question
