Dead Tri Glide
#31
Interesting, put the booster on it and still no crank and it did not light up the dash! Load tester shows battery good!
Look's like it is trailer time! We will see what HD's finest say the problem is. Has to be a fluke, don't see anybody else having this problem with Trikes/bikes this model.
We will see, may be something we have to watch but I'm betting it is just a one of problem.
#32
#33
The only other one I had go before was like an auto battery, solenoid chatter or clicking and the gauges hands all moved with the gauge lights coming on.
Dropped it off at the dealer, will know in a few what the deal is! Warranty is good until Aug. 6 so we will see how much post warranty I get bit for. If it is a battery there may be a prorated charge for the months on the battery before it failed.
![Icon Shrug](https://www.hdforums.com/forum/images/smilies/icon_shrug.gif)
#34
You may be right but I did manage to jump a bike with a battery that had a dead cell. I'm wondering if it has a blow maxi fuse? There is a 40 amp main fuse that if it blows nothing works, its a big bugger which can't be missed.
#36
I started to check a few of the inline fuses but didn't want to get to far into it and give HD an excuse to void a warranty. I think you need to unhook at least one end of a resister or fuse in some circuits to get a good reading.
#37
Coupe55, Did you check the 40A max fuse (main fuse)?? I thought by your earlier posts that you had . As dead as your TG is that would have been one of the first to look at. If you didnt my bet would be on that and if it did blow what caused it, thats a lot of amps.
#39
The dealer called and it was the 40 Amp main. The only interviening event was when I tripped over the charger cord, bounced it around pretty good and it jerked the connecters loose.
Oh well, they said they did a continuity check and all the other circuits looked ok and everything is working. With all the small amperage circuits with no blown fuses one would assume the big one would have been ok but you know what they say when you assume!
I guess we have learned the ol Harley circuit protection is a pretty good one. It acted as designed and the main blew very fast as the small amperage circuits did not blow. I will buy an extra main and see if another cause shows up later on but as it stands it looks like the spike may have come form when I tripped over the float charger?
Looks like you won the Root Beer Ice, don't tell anyone about my senior moment and I'll make it two..
![Icon Toast](https://www.hdforums.com/forum/images/smilies/icon_toast.gif)
