Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Removal of seat
Old 07-27-2013, 06:05 AM
Fusionfool's Avatar
Fusionfool
Fusionfool is offline
Thank you all for the feedback. It is a 1/4 x 20 thread right?
Old 07-29-2013, 08:03 AM
Boom's Avatar
Boom
Boom is offline
I've been using a 1/4-20 cap head screw with hex inset on my Zeppelin seat. I tighten with a long ball-tip allen wrench. But you still have to get the screw in there upright so you can tighten without cross-threading. I'm looking for that thumb screw.
Old 07-29-2013, 08:40 AM
JJHOG's Avatar
JJHOG
JJHOG is offline
Why don't you guys simply used a double threaded 1/4 x 20 extender. Put the thumb screw on one end and then thread a long piece of 1/4 x 20 all thread using red locktite or even locking it in with a nut and lockwasher on the other end.
Old 07-29-2013, 11:18 PM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,083 Likes on 3,485 Posts
Why use something like all thread that eats up everything that gets next to it ??????
You do have a point about having threads at both ends tho. So cut the head off a bolt & thread the top to screw on a **** with red, or green loctite. If you do use all thread, put a cover of a rubber or plastic tube to protect everything from the threads.
Also you can also slightly point the threaded end as to find the threaded hole easily, and shorten the threads if you want to screw the bolt less.............
Always keep it simple !
Old 08-02-2013, 02:54 AM
writeman's Avatar
writeman
writeman is offline
This is my fix for the seat screw. I used a double nut on the bolt. All parts purchased at Ace Hardware.
Attached Thumbnails Removal of seat-img_0013.jpg   Removal of seat-img_0008.jpg
frenchbiker (05-10-2017)
Old 08-02-2013, 03:06 AM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
That will work fine, but if anything gets against those threads, it will eat it like a file. Like your seat when someone is setting on it ?
The addition I would make to it is a piece of rubber tubing like surgical or any thin rubber tubing just to be safe.
I have the Road Zeppelin seat, & the pad goes back farther. Maybe yours won't reach it. How about the back lower pad?
Just my opinion........
Old 08-02-2013, 05:50 AM
JJHOG's Avatar
JJHOG
JJHOG is offline
Writeman, looks good but add the clear vinyl tubing as suggested to be on safe side.
Old 08-02-2013, 09:23 AM
UTES's Avatar
UTES
UTES is offline
I'm not sure how important the seat retaining screw is. I discovered last night mine's gone MIA. And, I had not noticed until then. My seat fits pretty snug and does not move around. I may not replace the screw and am thinking of fitting a short stud the rear seat mount fits onto.
Bill
Old 08-02-2013, 05:21 PM
Tanker06's Avatar
Tanker06
Tanker06 is offline
Not related to this specific problem, but I'll tell a little seat related story on my self.
I bought my '11 Tri-G from the original owner. It has a driver back rest. I figured out that the screw in the back would release the seat, but did not know how I was going to get the seat over the backrest pad, so I took that off the backrest post so I could slide the seat over it. Once I had the seat off, I could see the release lever to pull the whole assembly off, DUH!!. I could also see the cable that led over to the lever that lets you adjust the angle of the backrest, which I did not know I could do.
You live you learn.
Wam
02-05-2018 12:00 PM
laabdog
04-20-2017 04:59 AM
bloozeman2002
05-19-2012 07:26 AM
buffettphan
08-04-2011 02:03 AM
Mr. Wizard
05-25-2009 02:45 PM
Quick Reply: Removal of seat
