Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tri-Glide Issues-2014 Trikes And Newer Rushmore Trikes
  #241
Old 07-03-2018, 11:41 AM
Donald Huson's Avatar
Donald Huson
Donald Huson is offline
Stage III
Originally Posted by COFLHTK
Tip sensor is out of alignment.
is there a way to correct that? Or do I need to replace it?
  #242
Old 07-03-2018, 04:07 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Oogie Wa Wa is offline
tIP reset: "Upright the vehicle." Duh. "Cycle ignition on and off and back, see if it comes up again." But you probably tried that.
So the part is called the Bank Angle Sensor (BAS) and it's behind the battery. It's an accelerometer. Just a small box with wires going to it that doesn't appear to do anything. But it cancels your turn signals after a turn and looks to see if the trike is upside-down.
If it petty much looks OK and the connector isn't corroded, first I'd give it a little whack and see if that helps. If the fasteners have loosened and it's at an angle, put it back and make sure it is square to the frame. Otherwise it will probably need to be replaced. Apparently the fastener length is important according to the manual, just keep the ones that have been in there for four years.
Cagmo (07-05-2018)
  #243
Old 07-22-2018, 10:55 AM
Tony Berkopes's Avatar
Tony Berkopes
Tony Berkopes is offline
Stage I
Log onto Amsoil web site. Sign up as a preferred customer, the fee is $20 per year I think. Order what u want at dealer pricing.
Tony
5wheels (07-23-2018)
Michele Lo Re
01-14-2019 01:18 PM
Mr.Softy
12-11-2009 05:36 AM
sddyna
03-13-2009 03:12 PM
PaleRearEnd
12-19-2008 03:11 PM
Anothernewguy
01-24-2006 03:21 PM
Quick Reply: Tri-Glide Issues-2014 Trikes And Newer Rushmore Trikes
