VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Adjusting VRSCA Vrod pedal distance
Old 03-16-2018, 07:22 AM
HD_HRSCA's Avatar
HD_HRSCA
HD_HRSCA is offline
5th Gear
Default Adjusting VRSCA Vrod pedal distance
Hello
I just bought a 2003 Harley VRSCA and had it delivered an hour ago. Does anyone know how to adjust the gear and brake pedal distance. I am 6ft tall but they pedals are too far away to be comfortable and safe. Thank you
Old 03-16-2018, 09:01 AM
PDB17UltraRG's Avatar
PDB17UltraRG
PDB17UltraRG is offline
Didn’t you do a test ride to see how the bike fit you prior to buying. There are linkage adjustments you can make your self but i would really Ride it like it is a while and get use to it. At 6 ft tall most complain there not enough room. Take back to your dealer they will help you adjust it.
Old 03-16-2018, 11:48 AM
HD_HRSCA's Avatar
HD_HRSCA
HD_HRSCA is offline
5th Gear
No, did not get a chance to try it out as it was in the next city and was only delivered in exchange for my 2 Kawasakis today. Worked out the problem. The previous owner was about 2meters tall and had custom extensions put on the pedals to put them further away. Beautifully done but will be removed shortly.
Old 03-16-2018, 12:07 PM
luigit's Avatar
luigit
luigit is offline
you need the stock foot controls. you could also try this site. https://www.alteredstatedesign.net/ great stuff
Old 04-21-2018, 06:36 AM
Gizmo02's Avatar
Gizmo02
Gizmo02 is offline
Would you be interested in selling the pieces used to move the pegs forwards? I may have the stock pieces if interested in trading?
Old 04-21-2018, 09:22 AM
HD_HRSCA's Avatar
HD_HRSCA
HD_HRSCA is offline
5th Gear
Default Pegs
Where are you located? I am in the Vaal area
Old 04-22-2018, 04:17 PM
Gizmo02's Avatar
Gizmo02
Gizmo02 is offline
I am in the United States
Old 04-27-2018, 02:21 AM
HD_HRSCA's Avatar
HD_HRSCA
HD_HRSCA is offline
5th Gear
Default Vaal
Ok, I am in a place called the Vaal which is about 70kms South of Johannesburg South Africa. When I get the extensions removed then we can make a plan
firehawk6
11-11-2019 02:37 PM
Big Bear
VRSC Models
11-10-2014 06:51 AM
racerdj
VRSC Models
10-15-2009 08:28 AM
MarksBOB
03-10-2009 11:15 AM
lencap
VRSC Models
09-13-2007 09:08 PM
Quick Reply: Adjusting VRSCA Vrod pedal distance
