V-rod muscle - rear tire mod
08-26-2010, 11:02 AM
Anyone tried to use a 280mm wide tire on the OEM wheel for the MUSCLE without modification? Is it possible at all?
Thank you,
LCL
08-31-2010, 11:13 AM
I know you cam get a 260mm in there with no modification. Haven't heard about 280mm, but that seems like it'd be pushing it.
08-31-2010, 01:41 PM
Thank you for the reply
I have seen a 280mm, looks really wide, but I also think it is pushing it too much.
A 260mm will do it in the future.
Thank you again,
LCL
09-01-2010, 11:37 AM
stock rim is a 8.0" so the max tire size you should consider is a 260. You would need a minimum 10.0" rim for a 280 tire so I would just stick with a Avon 250 Cobra or the Metzler 260.
09-02-2010, 08:32 AM
Tks for the input,
Take care and ride safe,
LCL
05-08-2011, 09:47 AM
What tire do you guys run for mileage. My stepson has to buy a new tire every 5k miles so hardly rides his vrod any more. Says he can't afford the tires.
05-28-2011, 05:54 PM
08-15-2017, 04:44 PM
Vrod Muscle Rear Tire
I have a Vrod Muscle. Looking to go from a 240 to a 280 tire. I have been told no from some and it's possible by others. Any insight to this ?
08-16-2017, 01:16 PM
Quote:
Originally Posted by
Kaivon
Yep! I had a 09 VRSCAW (twice!) I had switched from the stock 240 to a 260 - No problem at all...Had a Metzler 260 on it. Good wear from the Metz
I could have put a 280 on with no problem - but could not go to
a 300mm unless there was a swingarm change
Check out
www.1130cc.com they know VRod's..
08-16-2017, 01:25 PM
10 RED RK
Check out
I'm trying to go 280 which is the next step.
