13 spoke wheel fitment
Old 10-19-2016, 01:35 AM
Travleonard's Avatar
Travleonard
Travleonard is offline
Stage III
Default 13 spoke wheel fitment
So I have a late model dyna front end that is 39mm still but have the early style 13 spoke mags I have the correct bearings in for the axle but I can't seem to figure out the wheel spacing and caliper spacing has anyone done this before ?
Old 10-20-2016, 08:49 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,854 Likes on 2,420 Posts
Hi from the UK and welcome to HDF. We need more details before we can help, like what year and model is your bike? Are the wheels you mention the type that are fitted with tapered roller bearings?
Old 10-20-2016, 12:33 PM
Travleonard
Stage III
So the front end is off of a 2000 fxdx but the front wheel is off a 98 fxd with the timken style bearings in it I'm trying to make it all work on my twincam fxr
Old 10-20-2016, 03:44 PM
grbrown's Avatar
grbrown
grbrown is offline
Thumbs up
That sounds fascinating! We'll need photos when you're on the road!
You need to imitate the set-up of an original FXR, which will probably require different spacers either side of the wheel, compared with a twincam installation. I'm doing the reverse, installing a late front wheel in an early Evo Glide, but have yet to tackle the spacers. Bear in mind that an FXR may also have had a front-wheel driven speedo drive unit. You can compare the parts used on-line here.
You'll find the members over in the Evo section will be interested in this and may be able to offer help. Call by!
Old 10-21-2016, 10:41 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,265 Likes on 1,830 Posts
FRONT WHEEL Fitment:
Caliper(s) spacers...
The 2000-later Narrow-glide wheel is approx 4.390" Rotor "Flange" to "Flange". I think your 99-earlier FXD wheel is approx 4.050" (you might measure to confirm). So (4.390-4.050) / 2 = .170" per side needed for caliper spacing (if the wheel is perfectly centered or close to). Adjust dimensions as needed.
Wheel/Axle spacers...
I think using the Stock 95-99 Narrow-glide spacers (if no speedo drive) should work out for you. I think that even from the factory the wheel might be off center ever so slight, so the Calipers should/might be able to adjust using the Caliper spacer dimensions above. If not, you'll have to adjust cal spacer Dims accordingly
Also...Remember to use 99-earlier brake rotors on the 98 wheel
fxdlx (03-29-2017)
Old 11-02-2016, 12:40 AM
Travleonard
Stage III
Thanks for the info it was a big help I was able to get the wheel mounted and calipers spaced out perfect
Old 11-02-2016, 06:32 AM
multihdrdr's Avatar
multihdrdr
Thanks for coming back with an update. I always wonder about the ones that you never hear another "peep" from
Old 01-19-2017, 12:41 PM
MadMario's Avatar
MadMario
MadMario is offline
5th Gear
Could you post a picture or describe to me how you did that? I'm struggling with the same thing!
Mchad
EVO
05-22-2018 04:22 PM
Alumni
EVO
05-02-2013 09:46 AM
gioss
03-11-2013 07:39 PM
kennyflhr
Wheels/Tires
05-17-2012 09:14 PM
BobbyC1965
04-08-2011 12:37 PM
Quick Reply: 13 spoke wheel fitment
