'08 front wheel fit an '01 FLHTCUI?
Regardless, If it's definitely from a 08 Touring bike...
-Remove both 25mm ID bearings and center spacer sleeve. You should also find a bearing shim underneath the LEFT bearing (aka "Primary Bearing").
-Discard all the above parts
-Install 2000-07 1"ID bearings and center spacer sleeve (NO bearing shim).
**1. Install LEFT side bearing (aka "Primary Bearing") first.
**2. Insert center spacer sleeve
**3. Install Right side bearing until it just touches the center spacer
-Install your 01 11.5" rotors (in place of 08 11.8" rotors, if applicable)
