Front tire won’t hold air pressure
Received 48,003 Likes
Max Headflow (06-06-2018)
I like that low pressure idea. I’ll try it.
As for some some other advice given. I used soap. I checked the valve core and stem. And really? the right valve stem cap, wow,no not gonna go there.
The nail “was” in the rear. Fixed it the day I posted. The front still looses air tho. So if low pressure test does not fine it I’m pulling the tire off and remounting as much as I hat that it may come to that
I guess there is no “known” problem with the Comander II. That’s what I was after
thanks all.
thanks all.
Had to replace the commander II. The tire was separating on the inside where the two ends are fused together I called Michelin and in less than 10 minutes they agreed to replace the tire at no charge to me. With zero debase. All they had to do was call my local shop to confirm what I told them
Great customer service and standing behind their products at Michelin
Received 5,429 Likes
