Will 17" rims fit 2002 EGC
You`ll need to change to 1" bearings to fit your `02 axle ( brg 9247 vs 9252)
I strongly suspect the rotors will not work with your calipers ( 11.5" vs 11.8" )
@multihdrdr is the expert on wheel fitment
Leimy (04-25-2024)
You'll need to change out that ABS bearing to a STD bearing ... ((2) New brgs)
Get a 2008-later 25mm axle and wheel spacers and it's plug n play ... (other than rotors or calipers)
OR
Use 1" OE# 9247 bearings (as 88 mentioned above) and custom wheel spacers. The wider bearings will protrude slightly.
OR
Use 1" aftermarket bearings (same width as the 25mm bearings) and use semi custom wheel spacers
You'll also need 08-later Brembo Calipers for the OE Impeller / Enforcer 11.8" rotors (the 2002 use 11.5")
OR
Aftermarket Impeller / Enforcer 11.5" rotors to work with your 2002 Calipers
OR
OR
OR
eighteight (04-25-2024)
And thank you
Howdy,
OK.
I read every post.
I did order the new bearings , non abs, for that enforcer rim..
Now,
I like the idea of keeping brake calipers.
The rim does not current have rotors on the rim.
I need to get new rotors.
I think I understand I can get smaller rotors and keep the original calipers.
Where can I get the smaller size rotors?
OK.
I read every post.
Now,
Howdy,
OK.
I read every post.
Now,
OK.
I read every post.
Now,
https://www.ebay.com/itm/25502097380...mis&media=COPY
Howdy,
OK.
I read every post.
Now,
OK.
I read every post.
Now,
