Bearing Shim Part Numbers (HELP PLZ)
Okay in parts kit 41455-08C it calls for a 41450-08 shim for the front wheel on a 2008 and up Dyna.
You cannot buy this shim. Harley doesn't even list it as a valid part number. For the rear it calls for a 43904-08 (Rear Bearing Shim), and you can buy this shim. It is readily available. Also you can buy the 43903-08 (Front Bearing Shim) 2008 Touring model. My question is this. Does anyone know if 43903-08 and 41450-08 are the same part? If you can help. Plz let me know. |
What do you mean "it calls for?" Where does it state that?
In the installation instructions. In the PDF.
If you read down you have these ** in the "J" field for the front. Then it says to install the shim, and give the part number. Are you saying it is not needed. http://www.harley-davidson.com/en_US...ts/-J04051.pdf Read down for the installation to 2008 and above Dyna. Please give some more insight on this. |
41455-08C fitment states:
Front, 25mm Axle Fits '08-later VRSC™ models without ABS brakes, '08-later DynaŽ models (except FXDWG and FXDF) and '08-later Touring and Trike models without ABS brakes. Also fits '09-later Sidecar. 41455-08C breaks down to include the following: 40999-87 VALVE STEM 41123-79 VALVE CAP 41748-08 SLEEVE, FRNT WHEEL 705 41900-08 SLEEVE, FRNT & RR WHEEL 43157-83A VALVE STEM 43206-01 ASSEMBLY, VALVE STEM 43903-08 SPACER, FRT WHEEL BRG 9276 BALL BEARING, 25MM ID |
Thank you for that information. Why in the world is it listing a 41450-08 for my '08 and up Dyna? Could you discuss that?
Do you see in the instructions where it calls for that part? Also plz take a look at this: http://www.google.com/search?q=41450...ab9cbe03966427 |
I see that, but it is not listed in the parts breakdown for that kit. I also see under that kit for "J" it shows ** for dyna instead of an amount, but all the other amounts for "J" show 0. The notes for ** only state "bearing shim installed under the primary bearing." I don't know for sure, but I'm guessing you don't need it. If it is needed, then it has to be a misprint for that part number.
I see now.. Damn I feel stupid. ** says to read the "NOTES" under the Installation section, and if your "KIT" is listed you need those parts. Well my "KIT" isn't listed. So I do not need those shims. That is the way I am reading it, and if it was needed the *** means to install the shim under the primary bearing. Is that you way you are reading it?
By golly I think we figured it out, and I can go on with my install in the morning. I swear Harley manual jump around more than any other manual I have ever seen.. The Service Manual does the same thing. |
© 2024 MH Sub I, LLC dba Internet Brands
