Tapered Timken bearing
Old 12-13-2011, 08:44 PM
vinzilla's Avatar
vinzilla
vinzilla is offline
Default Tapered Timken bearing
Do tapered Timken rear wheel bearings only work on pre 2000 wheels? "Timkin bearing #LM11949" Can anyone tell me if this bearing will work on a 99 FXD or a 2000 Fatboy
Old 01-25-2012, 05:53 AM
FLYER's Avatar
FLYER
FLYER is offline
Most if not all of the twin cams had sealed bearings. The outer races are a little larger in diameter that the Timken bearings but the axles are the same size. So do you want to replace the later sealed bearings with Timkens? Usually people want to go the other way and replace the timkens with sealed bearings.
Magnut1
2014-2023 Touring Models
03-23-2018 11:06 AM
Trueno
05-08-2017 03:55 PM
junglejoe
Wheels/Tires
05-01-2013 07:28 PM
vinzilla
12-13-2011 08:41 PM
Hossman
10-02-2006 03:20 AM
Quick Reply: Tapered Timken bearing
