Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
How Shotgun Shocks Work... a write-up
Old 12-25-2016, 10:41 PM
02603SEC's Avatar
02603SEC
02603SEC is offline
Thanks for the well written explanation on how the SS works/adjusts it really finalized my decision on getting a set. Interested in what they are doing with the switches on new Breakouts, I have a 2017 and the horn is on the down tubes.
jam436 (03-20-2017)
  #52
Old 07-16-2017, 09:24 AM
SoCalSoftailSlim's Avatar
SoCalSoftailSlim
SoCalSoftailSlim is offline
Needed a little refresher on use of my SS this morning, and went immediately to this thread.
Just wanted to give it a bump, because it really is a gem, all these years later.
Thanks jam!
jam436 (07-17-2017)
  #53
Old 07-17-2017, 11:18 AM
jam436's Avatar
jam436
jam436 is offline
Thanks jam!
Thanks...
I got a little surprise last week when I found that Photobucket removed all my pictures, or rather they started demanding payment to link to them.
All of the illustrations I posted were gone.
This was one thread I wanted to make sure stayed intact, so I had to upload them all over again.
  #54
Old 07-19-2017, 03:15 PM
jreynolds's Avatar
jreynolds
jreynolds is offline
3rd Gear
Nice Writeup!
jam436 (07-20-2017)
  #55
Old 07-21-2017, 09:28 PM
Big Mule's Avatar
Big Mule
Big Mule is offline
Thanks for your write up. This is excellent information. I actually spoke to Jessica earlier in the week and I'm going to place my order on Monday. It just takes me a few days to get my head wrapped around spending the money. It will take about 4 weeks for it to be built.
  #56
Old 08-29-2018, 10:42 AM
SunDevil45's Avatar
SunDevil45
SunDevil45 is offline
Should be said that there are conditions that can occur that will affect height, so won't necessarily always will it stay at set height if there is a failure.
1. Piston seal failure. If the seal fails, air can leak from one side to the other. Because initial lift requires more pressure, this is the side that will typically bleed into the other, causing the bike to continue lowering until equilibrium is acheived. Bad piston and shaft seal, you're going all the way down and staying there.
2. Bad solenoid. If the dump solenoid fails open, your shock will lose pressure from that side, again this most commonly occurs on the higher pressure, initial lift side, so again, bike will lower.
If you run long pipes, be careful if you notice it losing height gradually. It can be a sign of this type of issue and if the seal failure becomes catastrophic, your bike will immediately drop to lowest level. If you have long fishtails and don't catch it quickly or are not cognizant of actual ride height, you can drag pipes pretty severely in turns. Mine caught good, enough to lose traction at rear wheel, but I was able to recover.
  #57
Old 08-30-2018, 09:51 AM
Low budget Dan's Avatar
Low budget Dan
Low budget Dan is offline
I have it printed and in my tool box
  #58
Old 09-16-2020, 01:58 AM
Chunky Monkey's Avatar
Chunky Monkey
Chunky Monkey is offline
Trying to mentally convert this to a bagger setup. It really is the mirror of everything but makes more sense than anything I found on YouTube explaining how to set up. Thanks!
jam436 (02-26-2021)
07ntrain
Air Suspensions
33
03-08-2024 03:35 PM
jgos929
08-20-2015 08:54 AM
Softail HA
06-09-2014 01:34 PM
hwyman
08-31-2010 05:42 PM
tanq
10-04-2006 03:53 AM
Quick Reply: How Shotgun Shocks Work... a write-up
