Auto volume problem
Old 12-08-2014, 10:52 PM
D.L.ANDER's Avatar
D.L.ANDER
D.L.ANDER is offline
Default Auto volume problem
Installed chrome lowers last weekend.I did remove the fairing and the ignition switch but changed no wiring . All went well but now my auto volume control is working in reverse. Higher rpm's and the volume on radio goes down. Also i think the volume control on the left grip has reversed. I have an aftermarket stereo and biketronics adapter. Anyone have any thoughts on the cause.
Thanks
Old 12-09-2014, 12:17 AM
Biketronics Inc's Avatar
Biketronics Inc
Biketronics Inc is offline
Former Sponsor
Hi,
This type problem can usually be traced to some sort of ground or power issue. Usually when the radio ground wire gets disturbed. If you want to give me a call 9-5 pacific time we can figure it out. Or if you would like PM me your number and a good time to call during our biz hours and I will contact you to get this fixed.
Bill
Old 12-09-2014, 07:42 AM
D.L.ANDER's Avatar
D.L.ANDER
Another great reason to buy from biketronics.great service.i will call when i can get to the bike.thank you and bt4180 amp is next on my christmas list
Old 12-10-2014, 08:12 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
Thanks
if you brought your battery voltage down too low while working on your bike it could have sent the BT module into a frenzy. Simply unplug it for a couple of minutes and plug it back in.
You don't mention what bike, what BT module, or what radio. If there are selector switches in play here for your particular head unit, sure you didn't accidentally bump something?
Old 12-10-2014, 07:57 PM
D.L.ANDER's Avatar
D.L.ANDER
Thanks for the help. I will not get back to bike till this weekend but will check both items. I believe i grounded system near the forks so will check that first. 2012 SG,sony head unit, soundstream amp. Bt7.1in fairing.6.5 Hertz in lowers and 6x9 pioneer in bags with seperate amp.
FHubbard4
Audio Systems
05-13-2015 08:38 AM
just plain john
Audio Systems
04-26-2015 09:57 PM
billd76
03-13-2012 12:48 PM
Trippie
11-12-2009 09:27 PM
jbhawley
03-13-2007 01:01 PM
Quick Reply: Auto volume problem
