pn4.1000d
Old 07-30-2015, 04:20 PM
northeimcustom's Avatar
northeimcustom
northeimcustom is offline
Also can someone verify my math for the dmm volts. I had 33.46 volts
Old 07-30-2015, 06:14 PM
haze324's Avatar
haze324
haze324 is offline
That’s what I get using 4ohms.
Using the Stock HU I’d try the HPF at it’s lowest setting and see how it sounds (add polyfill and put the fairing back on). The stock HU has some distortion at max volume, as powerful as that amp is you can clean that up a bit if you take out some of the lower freqs. I’d try it both ways and see if you get any distortion at higher volumes when set to AP. It most likely will sound better in your garage, but perhaps have some distortion at max volume on the road.
Have the hertz hsk’s gotten there yet??
Old 07-30-2015, 07:20 PM
northeimcustom
Thanks haze, yah I got the hertz in early this afternoon but didn't have much time to play around with it or polyfill yet. I was tuning it only going up to 13 bars for the stock HU and I had no distortion on full pass setting. Hopefully I will get a little time this weekend to play with it and try out the high pass setting.
Old 08-01-2015, 09:02 PM
northeimcustom
Update: I had a little time to play with the cross over and high pass setting. I am not sure which setting I am going to use. I have the high pass set around 65 ish. The full pass has a bit more bass. However I don't have my outer fairing on yet and it seems like these hertz hsk move some air. I don't think I am going to put the polyfill in. What does everyone else run with the hertz set up??
Old 08-04-2015, 02:59 PM
northeimcustom
What brand of speaker adapters is everyone using? I am not sure what brand I have but I think I need different ones , a little thinner because my hertz speakers are touching my outer fairing
Old 08-10-2015, 05:00 AM
JimTJr's Avatar
JimTJr
JimTJr is offline
What is that Honda over in the corner? A 350? Looks like my first street bike! LOL
Paul32730
Audio Systems
01-23-2019 07:12 PM
Terminator69
Audio Systems
05-22-2015 01:34 PM
gliding10
08-02-2012 07:10 AM
andyp
09-30-2010 05:35 AM
SICKBAGGER
05-30-2010 01:07 AM
Quick Reply: pn4.1000d
