Any ideas? help needed.
Old May 22, 2015 | 10:08 AM
Terminator69's Avatar
Terminator69
Default Any ideas? help needed.
hi I recently in staller a wetsounds amp 125 x 2 at 2ohm. (its almost identical to Arc audios amp only waterproof) along with the magic black box and amp install kit from sound streams and the infinity kappas 62.11i on my 14 streetglide special and it sounds like ****. I also put polyfil in my speaker pods like everyone suggested? Is it possible I may have put to much fil in the pods? Or Am I running to much power to them? They are rated at 115 rms with 225 peak so I thought they would b ok. I'm baffeled the stockset up sounded better!!!!
Old May 22, 2015 | 11:32 AM
SBates08's Avatar
SBates08
Your definitely NOT over powering them. I'd try removing the poly first and see how that sounds. Too much poly is worse than not having any.
2010 Limited with some stuff
Old May 22, 2015 | 01:30 PM
Terminator69
ok i'll try it, Thanks Bates.
Anything or anyone have more I would appreciate it.
Old May 22, 2015 | 01:34 PM
SBates08's Avatar
SBates08
Another thing some folk don't realize they can do, once your gains are set on the amp with the treble and bass in the flat position on the HU, you can adjust these to get the desired sound from your speakers but you must set gains first.
Streetglideclyde
Audio Systems
Jan 5, 2016 02:48 PM
Ragz Ultra
Audio Systems
18
Nov 20, 2015 12:53 PM
satchmo2014
Audio Systems
17
Mar 15, 2015 10:35 PM
ctso030
Nov 29, 2010 10:25 PM
Big Hog
May 23, 2010 11:18 AM
