HK Radio issues
Old 09-11-2016, 07:39 PM
Joker58's Avatar
Joker58
Joker58 is offline
6th Gear
Default HK Radio issues
I have a 2010 Ultra Classic and have radio issues. If I do a diag test I get no response from the right side switches? Left side all work. I did have my bars changed to a set of 13" bars and it all worked good for a couple months. No It will not change from the radio to the AUX if I want to listen to my music on my ipod ? Any one have any ideas where to start ? Also does any one have a wiring diagram for the right side switches to the main harness?
Old 09-11-2016, 07:42 PM
LiiT's Avatar
LiiT
LiiT is offline
Wrong part of the forum. Try this one!
https://www.hdforums.com/forum/audio-systems-153/
Old 09-12-2016, 01:54 PM
yooperhog's Avatar
yooperhog
yooperhog is offline
pick up an HD service manual. all wires coming from switches are color coded and manual has wiring diagrams in it. sounds to me like a pinched wire or poor connection. although... does your right blinker work? cruise? just radio funtions crapped?
Old 09-12-2016, 02:03 PM
Joker58's Avatar
Joker58
Joker58 is offline
6th Gear
the right side has the run stop which works ok . the start button works and the blinker works. it is just the cruise and the select buttons that don't work .the radio does not recognize the right side control at all when in diag mode.
Old 09-12-2016, 02:07 PM
yooperhog's Avatar
yooperhog
id check the connections at the molex connector under the fairing. im assuming whoever put your bars on pulled the wires internally? one poor connection in switch assy may fault the circuit
i have the manual at home. ill check the wire colors from radio controller this eve.
Old 09-12-2016, 07:28 PM
yooperhog's Avatar
yooperhog
added right hand wiring schematic. hope that helps
Old 09-12-2016, 07:48 PM
Joker58's Avatar
Joker58
Joker58 is offline
6th Gear
thanks
01XLH
2014-2023 Touring Models
04-26-2014 08:41 PM
CVO-RK
Audio Systems
11
04-22-2013 09:26 AM
rdbjac
Audio Systems
04-16-2013 12:23 PM
woodeyewetzel
09-26-2007 08:16 PM
cglofland
09-06-2007 07:45 PM
Quick Reply: HK Radio issues
