display not turning on my sony radio
Old Mar 22, 2013 | 06:51 AM
CVO-RK's Avatar
CVO-RK
Default display not turning on my sony radio
finally installed my sony radio and my display didnt turn on, is this a ground issue? I put the hawg wired adapter on as well dont know if this could be the issue as well hoping ultra nutz has a golden answer
Old Mar 22, 2013 | 03:15 PM
UltraNutZ's Avatar
UltraNutZ
ah sorry didn't see this....
make sure your fuse on your yellow wire is good. Check the connections for the yellow wire going into the radio.
Old Mar 22, 2013 | 08:30 PM
CVO-RK's Avatar
CVO-RK
im confused by what you mean by yellow fuse?
Old Mar 22, 2013 | 08:38 PM
UltraNutZ's Avatar
UltraNutZ
sorry I was thinking something else. The Sony harness that comes with the radio has a fuse on the yellow wire. That harness is not used when dealing with the BT or HW handlebar control devices.
The face of the unit, make sure it's seated properly. If those contacts aren't making a good connection when you close the face, it will not power up...
Old Mar 22, 2013 | 10:58 PM
CVO-RK's Avatar
CVO-RK
thats all good , still no go , I really think I have a ground issue cause now nothing is working
Old Mar 23, 2013 | 07:21 AM
UltraNutZ's Avatar
UltraNutZ
What bike are we talking about?
Old Mar 23, 2013 | 08:09 AM
UltraNutZ's Avatar
UltraNutZ
to test the ground theory you can simply take a piece of wire, touch one end of the wire to the case of the radio, the other end to a good solid ground and see what happens.
Old Mar 23, 2013 | 09:22 AM
CVO-RK's Avatar
CVO-RK
street glide
Old Mar 23, 2013 | 09:26 AM
UltraNutZ's Avatar
UltraNutZ
other than the ground theory above you need to check the red wire going into the radio that it has power when you switch the ignition off and on. and you need to check that the yellow wire going into the radio has constant +12v on it.
Old Mar 23, 2013 | 09:28 AM
CVO-RK's Avatar
CVO-RK
ok thanks will get back to you
